I had a problem with the boot open warning, rear wiper and the tailgate push switch all of which I have traced back to 4 broken wires in the tailgate loom (including the thick heater wire). I’ve patched these up and everything seems to work now except I still get the boot open warning and the extra beep associated with it when I lock the car. Will this be the micro switch in the lock itself or something else?
Which wires did you fix?
I assume you fixed the white/orange (tailgate push switch), brown (heater), white/green and green/brown (wiper) but what about the white/gray wire which is for the micro switch to detect closed tailgate?
Hi. Thank you for the reply. I’ve fixed the yellow/grey, yellow/orange, green/brown. The thick brown/yellow I’ve not connected yet but presume that’s for the rear demister. I’ve got 4 wires that seem intact (purple, green/white, yellow/green and yellow).
Ok it seems you have different wire colors than indicated in the workshop manual I have
The color coding in the attachment are the following
A: Light blue
B: White
C: Orange
G: Yellow
H: Grey
L: Blue
M: Brown
N: Black
R: Red
S: Pink
V: Green
Z: Violet
And a two letter description is just a combination of colors
Thanks for your help. I’ll take a more thorough look at it when it decides to stop raining on my days off!
I found that the white on the white / grey wire for the boot open warning was not very white on my 2012 1.4 8v. It is the very thin wire.
Thanks Nitram. The wire that I thought was yellow/ grey probably is white/ grey. Anyway, I’ve checked the wiring for continuity to the lock and all checks out. In fact, the first time I locked it it didn’t give the extra beep so I’m thinking the lock itself might be faulty (or rather the switch inside).
The switch spends most of its life with the boot closed, and the switch contacts can corrode, i found operating the switch a few times stopped the annoying problem.
