Driving to work this morning and my injection system failure warning light come on.
This resulted in loss of power and now i'm very worried.
I plan to take it in to Alfa tomorrow morning but i just wondered if anyone on here could shed any light on what it might be? and more importantly how much it will cost me to fix it.
Any help would be hugely appreciated
As CJ says, the loss of power was probably the 'safe mode' kicking in to protect the engine, rather than a direct symptom of what's happened, so don't panic yet. Until the fault code is read off the ECU there is no way to tell what the issue is.
I wonder if anyone can help following on from the above.
I took the car in, guy said dpf was blocked so he performed a regen.
He said it would be best to remove the DPF altogether though.
Light was off when i picked it up and fine again.
3 days later though and the light comes back on and back in safe mode.
Called the mechanic and he said bring it in Friday and he will perform another regen.
Thing is the light has now gone off and driving fine.
All seems a bit strange to me and not too sure what to do now.
Do i still take it in 2mora even though there is no light?
Or shall i take it for a blast down the motorway 2nite?
I think I would make sure there is at least half a tank of good fuel, not super market fuel in it and give it a good run on the motor way, look out for signs of a regen, slight change in the exhaust note and the turbo gauge dropping very suddenly when you lift off. if it does start a regen just drop it down into 5th to keep the revs up and let it complete the regen.
Funny that it needs another regen only three days after a forced regen do you do a lot of around-town driving? Otherwise something upstream may be generating a lot of soot, causing the DPF to block.
Related Threads
Alfa Romeo Forum
7.1M posts
216.7K members
Since 2001
