156 - Rough idle, unsure respons and bad recharging!
995 views 3 replies 2 participants last post by  Malheus
#1 ·
1. Recarding! If i drive less than 10km, the car wont start after
It charges about 12.10 with maximum load and 13.80 without any load
Death or do; change the generator/alternator by myself? Anything to keep in mind? I got "all" tools without Alfas own, unless Ford, Subaru or Kia share something ;P
2. Lately the idle been worse and worse..First when i bought the car, idle when mrrough ( Dat explain ) and jumped up and down a bit before laid down. I changed the MAF and it got MUCH quicker but the idle jumping remained; but less.
Now idle is almost terrible, if you give throttle it coughes a bit sometimes and sound like a 1.4 with choke ( I had an 340 1.4 before ;P ). It acts unsure SOMETIMES. Also the whole car cough if you release throttle sometimes. If i put the A/C on it revs more ofc and idle gets more smooth..
Also readed somewhere that if you put feet against cluch and rev; it if shake 2nd injector is bad? I noticed something oil/gasolineish at it..havnt look closely; yet.
No lights showing up ! Tried with some all-round ECU checker but it didnt get respons
Suggestions..Make it charge again, change some injector and check of leaks in intake?
See less See more
