After sorting out my soggy footwell:thumbs: I now seem to have gained a judder when braking firmly(not hard) from 70-50 also after this when braking at slower speeds can feel a slight pulse(throb) through the brake-pedal.
Ive had the car since last Tuesday and the dealer had fitted new f/discs+pads, you can still see the dots on the discs.
Also a squeel started this morning at low speeds not sure if front or back but goes when handbrake or brakes are used. Anyone any ideas or is it a phone call and a good journey to dealer
strangely enough ive got a gtv with front discs with dots on the discs almost like dummy drilled discs,havnt seen it before never been on my other gtv/spiders.
I've had discs with those dimples, they are wear indicators. Supposedly when you can't make out the dimple any more it's time for a new disc. Either that or the dimple is obscured by the pad :lol:
Even after bedding in new pads I sometimes get some pad material deposited on the front discs, which can make the brake pedal feel a bit lumpy. Happens more if you brake to a stop and keep your foot on the brake pedal. I just take the car our for a blast and get the brakes nice and hot, which seems to clean them up a treat and eliminate any lumpyness.
When I was looking for new brakes discs I found some brake discs have holes some have dimples and some nothing at all. I know EBC do dimpled discs. I think the dimples are intended to help cool the disc and help remove the gasses generated under braking, similar to holes but they should be all around the disc.
Hi Guys, can't add any comment to posts on the front brakes - you've got it covered, but a squeal on the rears is often caused by the calipers not releasing properly (handbrake application stops the squeal) Solution is quite simple; remove the real calipers, and wind back the piston (using the proper tool), pump it back out (gently, or if its on the bench, use the handbrake lever) and repeat a few times - you'll feel it free up. This will usually resolve the squeal. I've done this many times on two 156's and my 3.0 GTV. If you don't do this, you can cook the discs/pads and end up with scary brake fade and a premature overhaul. Good Luck
Cheers for that sounds about right for the rear. I think the fronts are probably warped by the sounds of it find out tommorow
Thanks all for your comments
Related Threads
Alfa Romeo Forum
7.1M posts
216.7K members
Since 2001
